Printrbot Talk Forum • View topic - My first blob, in a while..
Postby ThereWillBprints2 » 2015-Apr-Mon-16-Apr
All my questions were worthless. Tuned by pitch first print in 8 months?
All in all I thought it would have done worse. This can be saved by increasing flow rate. See you in 3 hours with a Nightwing Mask, maybe.
ThereWillBprints2
Re: My first blob, in a while..
Postby orangefurball » 2015-Apr-Mon-18-Apr
Kinda looks like your bed is just uneven!
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Postby ThereWillBprints2 » 2015-Apr-Tue-16-Apr
I space the tape .1mm from each other to remove models easier from the print bed. It often looks like ruffles. It also helps peel off the tape as well. Support structure of 3mm is always used for a base to allow any Drexel work:)
The real issues I had are with A) outer layer speed does not match the layer speed. B) Unlike before where the constraints were previously supported by the slic3r and repetier and Cura, I now have to set all setting manually
I would like to thank you for the suggestion and I will make the replacement bed maybe next week. Right now I want movement because different tapes can compensate for the level discrepancies.
ThereWillBprints2
Postby orangefurball » 2015-Apr-Tue-18-Apr
Makes sense, the upper left portion of the print just looked as if that corner was higher and that the nozzle was simply scraping because it was too close.
Is that a stock aluminum Simple bed? I have an extra one that you are welcome to
orangefurball
Laser scintillater
Postby ThereWillBprints2 » 2015-Apr-Thu-04-Apr
It is not a simple print bed. I did use it as a template to make a clear acrylic print bed of 330mm width, pushed via fishing line :lol: . What I think you are seeing is the fold away table that I print on because I am really too cheap to buy a longer USB cable. I have a picture of it at the bottom. Smallest mask is 4.5 inch wide by 3.6 inch high. The one to the far right is 5.6 inch wide and 4.25 inch tall. Nozzle dieing on me which didn't help my calibration.
Funny story, I put a mini multi tool under the front of the bed. Which got me through the last of three attempts at a very thin Nightwing face mask.
All in all, 2/3 of the mask are going to be used for foam sheet templates. While the last one I will attempt to use some magic make up and build it into a face forming model. The tape will be removed via old school grinder at the lowest of speeds.
I am also putting the next part of my prints on hold until I get new tips. Hot End and gears/motors are working fine. These printers are tough, I will give the designers that. I also have no money/plans for a probe and to make a metal plate.
Enjoy the picture and ask for settings if you want :D
ThereWillBprints2
Postby orangefurball » 2015-Apr-Thu-11-Apr
orangefurball
Laser scintillater
Postby ThereWillBprints2 » 2015-Apr-Fri-12-Apr
I will actually use that for the mask!
ThereWillBprints2
