It is not a simple print bed. I did use it as a template to make a clear acrylic print bed of 330mm width, pushed via fishing line
. What I think you are seeing is the fold away table that I print on because I am really too cheap to buy a longer USB cable. I have a picture of it at the bottom. Smallest mask is 4.5 inch wide by 3.6 inch high. The one to the far right is 5.6 inch wide and 4.25 inch tall. Nozzle dieing on me which didn't help my calibration.
Funny story, I put a mini multi tool under the front of the bed. Which got me through the last of three attempts at a very thin Nightwing face mask.
All in all, 2/3 of the mask are going to be used for foam sheet templates. While the last one I will attempt to use some magic make up and build it into a face forming model. The tape will be removed via old school grinder at the lowest of speeds.
I am also putting the next part of my prints on hold until I get new tips. Hot End and gears/motors are working fine. These printers are tough, I will give the designers that. I also have no money/plans for a probe and to make a metal plate.
Enjoy the picture and ask for settings if you want
