by Mooselake » 2015-Apr-Mon-12-Apr
OpenSCAD's probably more difficult than Sketchup for most people (it's really a simple programming language), but in exchange it's more flexible, and it'll let you put customizable objects on Thingiverse (insert takerbot warning here...). It's nice to have several tools in your toolbox.
I've used Sketchup for other things, but not for 3D printing. I just tried a simple test to make a cylinder with more segments, to make it look more like a circle than a collection of flat pieces; the directions said to select the circle, and change the number of segments in it's entity info. It wouldn't work after the circle'd been extruded (latest sketchup 2015 makers ed), but will if you do it before extruding, so if you don't like the look you need to delete it and start over. Maybe it's just me; sketchup just seems to have a lot of little glitches that are livable for drawing outbuildings, but would make 3D objects difficult. I'm just not as good with it as the furball. None of this is to take away from your project, and it's just my opinion, of course, and I'm still a bit stuck in the drafting table and t-square days.
Check out Tinkercad,too. I think they'll give out free accounts again now that Autodesk's taken them over. It's how I did my first few 3D printer objects.
