Simple Metal Kit success
Postby cacb » 2015-Apr-Sat-08-Apr
Hi, I live in Norway and after a long wait I recently received my Simple Metal Kit. Btw., I have never seen a 3d printer in real life before, so it is a steep learning curve!
I must say I enjoy it, it has met all my expectations so far. I did the assembly in a couple of days without major problems. The Printrbot build instructions are really good, but you have to pay attention to the details, it is possible to go wrong. I made a couple of mistakes but was able to fix them.
I first printed a fan shroud using the sample filament, it worked out ok, if a little rough. Then switched to locally bought eSUN filament and I love it. The second print was a 5 hour spool stand (own design) :lol: and it actually worked. The only problem was a couple of "dislocations" in x-direction on the spool stand arms that I think was caused by a slightly loose bed clamp. After tightening it seems to be ok.
It is great!
cacb
Re: Simple Metal Kit success
Postby thawkins » 2015-Apr-Sat-08-Apr
cacb wrote:Hi, I live in Norway and after a long wait I recently received my Simple Metal Kit. Btw., I have never seen a 3d printer in real life before, so it is a steep learning curve!
It is great!
Congratulations, welcome to the club with the most number of crazy people in it.
You have done really well to get to this point.
thawkins wrote:Congratulations, welcome to the club with the most number of crazy people in it.
Thank you for that :D . I have been reading this forum for a while and observed the most common mistakes that people have been reporting, that has been really helpful to me. Lots of people with good knowledge here... thanks to the forum. Right now I am adding some parts to the spool stand, it will use a 32mm PVC tube as spool axis, so I need some adapters to center the spool. I have documented my build + experiences so far at arnholm full stop org for the interested.
cacb
Postby cacb » 2015-Apr-Sat-11-Apr
I have discovered a small problem I think can be attributed to the design.
I printed this "Finger Flobber" http://www.thingiverse.com/thing:446480 (had to scale it to 103%), and when reassembling, I managed to strip the outer threads in the motor where the screw pointed to below is attached. That screw is far too short, and after stripping the outer couple of threads in the motor it would not grip any longer. Luckily, I had a longer M3 screw and was able to fix the problem that way. Perhaps I used the wrong screw in the set originally, that's an easy mistake to do. Otherwise, the wrong screw length is provided.
cacb
Postby cacb » 2015-Apr-Tue-17-Apr
This kit has now seen another success, I got the heated bed upgrade working...
I printed a box I had printed on the unheated bed/blue tape with quite a bit of warping. Now on Kapton without any special treatment. When I turned the box to see the underside, I got this result. You can see every little turn. Should it be like this, or am I slightly high with the offset? Printed 1st layer at 190C and the rest at 185. Bed at 60C.
I took the opportunity to add a flat and a split washer under each bed corner so it can be leveled. It was quite "fiddly", but I managed. I am not 100% dialed in, I am using G29 as per normal, but I can see the rotation of the Z coupler is much less.
cacb
Return to My first blob
