I have Printrbot Simple Metal with a heated bed (put together form a kit) . I have been playing with it for a few days with only a little bit of success. I finally was able to print a decent 3mm box with help from Printrbot support in the form of an ini file for Cura. The problem I am having is printing the fan shroud. The base prints well but the layers don't seem adhere to each other as the layers go up.
I am using Cura. I am brand new to 3D printing, so I don't have any gcode or slicing experience. I am simply using the provided .stl file from the printrbot site with the settings that worked for my test box.
I am printing at 220 with the bed at 70. I thought this was pretty hot but it was what was suggested and it printed the box well. I have set my z axis but have not made any changes to x and y. I got a perfect print of the 3mm test box.
Does anyone have any ideas of what I should try? I am so frustrated!
