Printrbot Talk Forum • View topic - Simple metal printed fine yeaterday, and then......
Postby SteveS » 2015-Mar-Wed-22-Mar
Hi all, I got my bot yesterday, spent a lot of time to get it setup, printed a couple of items, everything was fine after I got it dialed in. This morning, I went to print a spool holder, and here is what happened.
I had to go back and repeat the setup, before it would print properly. My hotend temp was 210c, hotbed temp 60c, using sample pla I got with printer, print speed 50, same as yesterday.
Any ideas, or did I not supply enough, info.
Thanks in advance, really am enjoying 3D printing.
SteveS
Re: Simple metal printed fine yeaterday, and then......
Postby SpannerHands » 2015-Mar-Wed-14-Mar
Maybe you did not save the settings with the M500 Command? I have done this before as soon as you power off it goes back to the last saved settings...
Everything for your 3D & Filament Needs.
3D Printing Filaments PLA, ABS, Wood, Transparent, Flexable and Technical Materials.
www.spannerhands.co.uk
SpannerHands
