Hi, I've had some good prints with the translucent filament that came with my Printrbot Metal Plus. But, it ran out.
I moved on to a roll of white PLA filament that I got from Adafruit.com. Things are a little off.
At first, layer 1 temp of 195, didn't see to stick too well to the bed.
I'm now at 205, with 200 for all other layers. The first layer sticks fine, but I'm getting very large spiderwebs. The webs I think suggest the temp is too high, but any lower and I get some non-straight lines being made (little curly cues). Maybe the temp is still too low? Maybe I need to reduce the flow rate?
Bed temp is 70C.
I'll post an image of my first white print later. I got cocky and tried a cell phone case. Not such a great result. There are bumps along the "smooth" sides, and lots of thick webs from when the printer moved from location to location.
One thing, I did set the extruder nozzle size down to 0.4, from the default of 0.5 in repetier. I think I read somewhere that maybe 0.3 would overcome some issue with repetier, but then my first layer thickess is off. Should I go back to 0.5mm?
Most of prints up to now looked good with the translucent filament, but I can't say how solid a solid face is, seems more like a screen than a wall. I can see light pass through openings between filaments in the first cube for instance. I thought that changing the extruder nozzle size would fix that.
Thanks,
John
