by mcdader » 2015-Feb-Thu-11-Feb
Thanks,
So another quick question. Trying to print out a few more things and noticing prints smaller than expected. So I printed the Nickle calibration print and the nickle will not fit. Too small. Using my Calliper, I measured all my axis's, when I tell them to move 10mm, they are all moving the correct distance, Also measured my extruder, it is also using the correct amount of filament. Just not sure what to adjust for this.
Using Cura
Layer Height .2
Shell Thickness .8
Fill Bottom/Top thickness .6
Fill Density 100 (for this print)
Print speed 40 mm/s
Temp 198c
filament
diameter 1.75 (checked with calliper)
flow 100%
Nozzle .4
Retraction
speed 30
distance 1
Initial layer thickness .3
Travel speed 70 mm/s
Bottom layer speed 20 mm/s
Minimal layer time (cool) 5 sec
Thanks again for the help.
