by RetireeJay » 2015-Jan-Wed-08-Jan
That print actually looks pretty good.
The diameter of holes is a well-known problem. Even the big commercial printers don't produce absolutely accurate holes.
But that said, the first things to look at are:
1) Extruder calibration (The steps per mm of filament going in to the extruder. Don't use a stock value, because machines differ; measure it yourself and get it right.)
2) ACCURATE measurement of your actual filament diameter (cut off two or three pieces about 20mm long, and measure with digital calipers for both the smallest "diameter" and the largest "diameter" on each piece; then take the average)
3) Tweaking the "Extrusion Multiplier" to get the most accurate dimensions possible.
Changing the extrusion temperature will have a very slight effect compared to the above three - which are first-order effects.
