Printrbot Talk Forum • View topic - Small overhangs curl UP
Postby Sigmoid » 2014-Nov-Thu-11-Nov
Hey,
So far I'm extremely satisfied with the surface finish of printed objects, the only problem is that I haven't been able to complete any due to small overhangs curling up. Note, it's NOT the bottom of the print that's curling, and it's not ABS, it's PLA. So this curling is not that curling. ;)
When printing overhangs, it looks as if there was too much plastic extruded, and the whole thing curves upward more and more with each pass. At first the hot-end pushes it back down, but after a while the plastic hardens, and as the hot-end tries to print the next layer, it hits the curled overhang - which, acting as a lever, rips the entire print off the bed - and the print is pretty much ruined from that point on.
I've read two explanations...
One explanation is that it's due to insufficient cooling. A suggested solution was to reduce printing temperature - I'm printing at 185C, I don't think it goes much lower than that... The other was to improve cooling - I set a minimum layer duration of 15 seconds, with cold wait, which improved the situation, but didn't wholly get rid of it - the print still failed, only later. I'll try printing the fan shroud, and see if it helps.
The other explanation was that it's due to over-extrusion. I have only read this once... It certainly does LOOK like over-extrusion, but regular areas that aren't overhangs print quite beautifully.
Anyone had this problem and solved it successfully?
(The print I experienced this on is the Ultimaker robot, which is the "demo" print in Cura. It fails where the body of the robot begins, with a sudden overhang.)
Sigmoid
Re: Small overhangs curl UP
Postby RetireeJay » 2014-Nov-Thu-12-Nov
Are you trying to print this puppy standing up (oriented like in your picture)?
It's impossible, at least without "support" turned on. Look at the "fingers" on the hands. If you are printing it standing up, then the bottom tips of those "fingers" are not supported by, or attached to anything at all until upper layers get printed later.
Most of the pictures of the robot on Thingiverse seem to have the robot printed lying on its back. Even then, either the arms must be lying on the bed or else you must be printing with "support" turned on.
A truism of 3D printing is that you can only print very small overhangs. You can do sloping sides up to about 45 degrees away from vertical. You can also do "bridging" where you connect two pillars with a horizontal bridge. But without "support" you can't do horizontal overhangs or isolated objects like those robot fingers.
Postby Sigmoid » 2014-Nov-Thu-12-Nov
Sigmoid
Postby Mooselake » 2014-Nov-Mon-20-Nov
It's from the extrusion stretching while printing, then pulling back as it cools. I had it trying to print a model of a human inner ear a couple years ago for Mrs. Moose (she's an audiologist), and it took some digging to figure it out. There's an old discussion on the reprap.org forum . Or google "3d printing stretch curl" (minus the quotes).
It's related to the width of the printed filament, the narrower the extrusion the more it's stretched (by extruding slower relative to head movement) to be smaller relative to the nozzle orifice size. Change your printed extrusion width so it's wider, if Cura gives you that option (sorry, don't remember if it's in Cura or not; it is in slic3r). If not, you may be able to fake it by specifying a somewhat larger nozzle so it'll automatically pick a bigger width.
Postby Sigmoid » 2014-Nov-Sat-22-Nov
Sigmoid
