how did you print Mr. Jaws without warpage?
Postby bakemono » 2014-Nov-Sat-16-Nov
thingiverse thing 14702
I've tried five times to print this, with various settings, and the nose and fins always curl up rather than staying flat against the bed. I'm using PLA on a Printrbot Plus. Started with default settings, tried more fan, less fan, less heat, slower speed.
bakemono
Re: how did you print Mr. Jaws without warpage?
Postby orangefurball » 2014-Nov-Sat-20-Nov
Are you printing on tape?
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Postby bakemono » 2014-Nov-Sun-00-Nov
yes, kapton
"The minimum number of characters you need to enter is 25."
I love forums :roll:
bakemono
Postby orangefurball » 2014-Nov-Sun-00-Nov
bakemono wrote:yes, kapton
Personally, I have never been able to get PLA to stick to Kapton. Try it with Scotch Blue 2090 tape with your bed at 50-60C. Make sure its 2090 as this is the best for printing. It is also called Original Multi-use. I'll put a picture of one of my rolls below.
Kapton is really good for ABS, you may also want to try some lightweight adhesive spray on glass, hair spray on glass, or even a 4:1 mixture of water and PVA glue on glass. In the United States, PVA glue is Elmer's brand school glue.
[img]http://tapatalk.imageshack.com/v2/14/11/01/dc2b6efc45dd1b79e09811772457d0ea.jpg[/img]
orangefurball
Laser scintillater
Postby bakemono » 2014-Nov-Sun-03-Nov
Aha so kapton is better for ABS then... I have some ABS filament but haven't tried printing with it yet. I started with PLA because it sounded like that would be easier to work with.
I changed my filament diameter setting from 1.70mm to 1.66mm which I assume causes it to extrude slightly more. It seems to counteract the shrinkage of the bottom layers. I had to increase the retraction to prevent spider webs. But now I am able to print a shark with only slight warpage.
bakemono
Postby orangefurball » 2014-Nov-Sun-03-Nov
bakemono wrote:Aha so kapton is better for ABS then... I have some ABS filament but haven't tried printing with it yet. I started with PLA because it sounded like that would be easier to work with.
That is correct. I have never used ABS, but it is better than PLA on Kapton tape.
Instead of changing the diameter settings, you can either increase your first layer height, add a brim, or add a raft too. This will help keep everything consistent.
If you are using Repetier Host, you can also change the Flow rate for the first layer and then put it back to normal after you have a good first layer put down.
orangefurball
Laser scintillater
Postby Mooselake » 2014-Nov-Sun-12-Nov
Elmer's washable school glue stick (the kind that starts purple and dries white) on glass works great for PLA, and is easier than hairspray, abs goo, etc. It washes off easy when you want to clean up the glass and recoat, although I usually just spread a little more where the part came off.
Postby orangefurball » 2014-Nov-Mon-01-Nov
Mooselake wrote:Elmer's washable school glue stick (the kind that starts purple and dries white) on glass works great for PLA, and is easier than hairspray, abs goo, etc. It washes off easy when you want to clean up the glass and recoat, although I usually just spread a little more where the part came off.
[img]http://tapatalk.imageshack.com/v2/14/11/09/9c617c9eaa1e480057880456d5aa15ae.jpg[/img]
My goodness, look at these layers. Elmer's washable gluesticks are where its at.
Bed at 60C with a liberal amount of glue is giving me the best first layer I have ever had in my time printing. Thanks you!
orangefurball
Laser scintillater
Postby bakemono » 2014-Dec-Fri-20-Dec
Yes the glue stick works wonders. I tried it after my first attempts at printing ABS failed horribly. With a light coating of glue on the bed nothing has curled up. I've been able to print all these doodads:
bakemono
