g01 gcode confusion????
Postby arshia » 2014-Jul-Sat-02-Jul
plz help me out ...i have a big confusion about g01 gcode.
if i have this command
G01X02Y02F100
then what does it mean???
i think it means that first tool move 2 inches or mm in x direction by the motor of x axis then tool will move 2 inches or mm in y direction through the motor of y axis and and reach at (2,2)???
or it means that both motors (motor of x and y axis both) move simulatneously and the tool will move in diagonal line at an angle of 45degree and reach at (2,2) ???
arshia
Re: g01 gcode confusion????
Postby thawkins » 2014-Jul-Sat-06-Jul
arshia wrote:plz help me out ...i have a big confusion about g01 gcode.
G01X02Y02F100
Both move simultaniously. Its a vector from x.current,y.current to x.current+2,y.current+2
Postby RetireeJay » 2014-Jul-Sat-06-Jul
By the way, units are always in millimeters.
Postby arshia » 2014-Jul-Sat-07-Jul
G01X02Y02F100
okay...nd the angle of diagonal will depend on the starting and ending coordinate.right ?????
arshia
Postby thawkins » 2014-Jul-Sat-11-Jul
G01X02Y02F100
On a g1 move the system sets the speed of movement of the x and y (and z if specified) such that movement is proportionat in each dimension, ie at 50% of the time through the move, the head will have moved 50% of the x distance and 50% of the y distance for example, so the path of the head will describe a staight line from the initial 3d coordibates to the final 3d coordinates.
