First Real Print! LG G2 Phone Dock with Wireless Charger
Postby ridestp » 2014-Jun-Sun-20-Jun
After a couple calibration prints, I fired up 123D Design and made a dock.
The project is at 123dapp [the dot c o m goes here] /Project/LG-G2-Dock/2427175
Yeah I have a messy desk setup but it works!
The dock holds the phone at a 15 degree angle. The Nokia DT-900 charging plate is held very firmly in place, and the phone has about 1mm of wiggle room. I even made a speaker port on the front!
Had an issue with the filament binding on its way into the extruder, which threw off the positioning in the lowermost portion of the base, and one side of the base warped upward. Other than that, it was smooth sailing!
ridestp
Re: First Real Print! LG G2 Phone Dock with Wireless Charger
Postby Baedarlboo » 2014-Jun-Mon-06-Jun
Nice print! I've also been messing around with 123Design...it's pretty basic so easy to use.
Baedarlboo
Postby Michele31415 » 2014-Jun-Thu-00-Jun
Nicely done. You also gave me an idea for the world's simplest spool holder - just punch a rod through the box the filament came in just high enough for the spool to ride on it.
PB+ no. 2548 (Oct. 2012) - This is my Printrbot. There are many like it, but this one is mine.
GT-2 belts and metal pulleys, x&y; Injection molded extruder gears
40 mm. cooling fan, glass bed, LED extruder lights, pilot light
Anti-jam extruder feed tube, roller filament guide, soldered bed heater connection
Michele31415
