Printrbot Tinkerer from Argentina
Postby jaytuduri » 2014-Jun-Wed-10-Jun
Greetings everyone! I'm Joaquín (or "Jay") from Argentina.
I finally assembled my Printrbot Simple 2014 (aluminum extruder + bed) this past weekend. Fun project
Here are some of my first prints.
1- 5mm step calibration piece
2- Vector Calibration piece
3- Batman Batarang - with this wider piece I realized i hadn't levelled the bed properly.
Thats all for now!
jaytuduri
Re: Printrbot Tinkerer from Argentina
Postby RetireeJay » 2014-Jun-Wed-10-Jun
Good job! :)
Return to My first blob
