First Print
First Print
Postby Sintax » 2014-May-Fri-19-May
Just printed my first calibration cube, it turned out amazing but there is one issue, warping... i looked online for some fixes and was checking if there was something i may have missed if you guys know some good ways to get rid of warping please post :D.
Sintax
First Print
Re: First Print
Postby RetireeJay » 2014-May-Sat-09-May
Unfortunately, there are so many different ways to describe the same phenomenon that it can be difficult to search. Your "warping" is almost certainly a lack of adhesion to the print bed. There are dozens of posts about that issue. This post has links to some of the best posts. viewtopic.php?f=16&t=7033
Re: First Print
Postby slicedveggie » 2014-May-Fri-08-May
If you could, post a picture if what you are getting. As Jay said - lots of different potential solutions to that one word.
If you're talking about corners lifting from the bed - as Jay said, lots of posts about that too, but the thing that worked great for me (when printing with PLA on my SimpleXL 2014), is blue painters tape thoroughly wiped down with rubbing alcohol.
slicedveggie
Return to My first blob
