My First Print, issues...
Postby Will_Maunders » 2014-May-Fri-14-May
Hi there,
Just built my Jr V2.
Can anyone please look at my print.
I have the bed set to 70 and the hot end set to 185 for all layers. but as you can see in the photos the first few layers seems to be really stringy, seems to happen with what ever i print... I'm pretty happy with the z axis, with a business card distance between the hot end and bed across.
Does anyone have any pointers?
Many Thanks
Will
Will_Maunders
Re: My First Print, issues...
Postby plexus » 2014-May-Fri-15-May
Welcome, Will. That could be caused by insufficient extrusion. since the rest of the print looks ok, you might want to check for extrusion issues when you see that happening. the way I do this, is to grab the filament as it feeds into the printer and feel it being pulled it. you don't want to pull on it so much that you are pulling on it but you want to feel it being fed in. you want to feel it feeding proportionally to the manner in which the extruder motor is turning. you might want to put a line on the hobbed gear so you an see it turn. the idea is that you want to feel if the filament is slipping or not. if the filament is feeding ok, then you want to extrude some filament at typical speeds with the hot end up a bit so you can watch the filament come out of the nozzle. again you are looking for consistent smooth extrusion. if not then you may have a blockage or issue with the hot end.
There are other things that can cause this but the first thing to check is extrusion. report your findings and we can help you further.
Postby Jdublu » 2014-May-Fri-15-May
Are you printing a skirt before the cube prints? I set my first layer temp 3-5 degrees hotter than my additional layers and use a two loop skirt. The skirt helps get the extruder flowing prior to printing and the higher first layer temp helps stick it to the platform.
Metal Simple
E stepper heatsink w/fan
Z axis stepper heatsink w/fan
Extruder fan
Hotbed relay fan
6"x6" Heater board
40 Amp power supply
S. Florida
Jdublu
Postby Will_Maunders » 2014-May-Fri-15-May
I have tested my extrusion and asking for 10mm is pretty much spot on plexus.... and Jdublu, Im currently asking for 3 loops, but to be fair it doesn't usually start setting until after the first or second loop....
Any ideas?
Thanks
Will
Will_Maunders
My first loop is usually about 80% complete, second loop is 100% and is slightly compressed, thickness wise. In cross section, it is much more of an oval than a round bead. If you aren't getting that little bit of 'squish' you need to adjust your Z height.
Metal Simple
Extruder fan
Hotbed relay fan
6"x6" Heater board
40 Amp power supply
S. Florida
Jdublu
Ok Jdublu, its currently set to about a business card, you reckon i should try to reduce it slightly then yeah?
Will
Will_Maunders
Postby killbox » 2014-May-Fri-18-May
most people use paper, the card is a bit too thick. my guess it would be around a full layer height as apposed to the needed half layer height
Ramps 1.4
LCD
E3D V6
8x8 Hotbed
smoothieboard
killbox
Postby Will_Maunders » 2014-May-Sat-07-May
So i readjusted the hot end till its just a papers width away from the bed.
As you can see I'm getting much better results on the base of the model.
Still got a few issues to deal with, if anyone can give input i'd really appreciate it!
1) The very top block/ square appears to have very rounded corners compared to the rest, I assume this is down to the small surface area and print time per a layer? what would be the best way to solve this?
2) Where it is bridging over a gap some material is sagging down, does anyone have any idea why this is and again how to overcome?
Thanks!
Will
Will_Maunders
Postby slicedveggie » 2014-May-Fri-08-May
In your top block - you are right on in your assessment - its got a super short build time and doesn't have time to cool properly. Make sure your cooling is turned on and then you can also slow your build speed way down to give it time to set and cool. As far as bridging, theres some good discussions about that on the forum. Its sort of an art that combines speed/acceleration, temperature and cooling. Check out this thread and look at Mochaboy's solution - viewtopic.php?f=15&t=5724&p=37094&hilit=bridging#p37094
slicedveggie
