First print: Fan support for the 2014 simple
Postby Nostromo82 » 2014-Apr-Wed-12-Apr
Hello out there
just finished building my 2014 simple two days ago, after some calibration and some simple tweaks (extruder spring tension, software eg.) I was able to produce the first usefull part.
It is a fan support for the 2014 simple to cool down the extruder gear. It can simply be attached to the Y-axis via the existing screw (has to be replaced with a bigger one), and is available on Thingiverse by looking for "Printrbot Simple 2014 Fan Support" (sorry can't post the direct link due to the "new user" rules).
Best regards from Switzerland
Nico
Nostromo82
Re: First print: Fan support for the 2014 simple
Postby sarahspins » 2014-Apr-Wed-12-Apr
sarahspins
Thank you very much :D
Have to make some more pictures when the fan arrives.
Nostromo82
Return to My first blob
