First print... some funkiness
Postby fwillerup » 2014-Mar-Mon-01-Mar
My first print from the Printrbot simple 2014 -- using the settings from the Getting Started Guide.
A little stringy looking.
I will start tuning things, but would of course welcome any pointers as I am completely new to 3d printing.
Thanks,
Fred
fwillerup
Re: First print... some funkiness
Postby fwillerup » 2014-Mar-Mon-23-Mar
Figured out my issue: major user error! I had updated configuration settings for slic3r but settings didn't take because I hadn't selected the presets in the dropdowns on the Slicer tab in Repetier-- so it was printing using the defaults. Prints are much better now!
fwillerup
Postby sarahspins » 2014-Apr-Tue-00-Apr
fwillerup wrote:Figured out my issue: major user error! I had updated configuration settings for slic3r but settings didn't take because I hadn't selected the presets in the dropdowns on the Slicer tab in Repetier-- so it was printing using the defaults. Prints are much better now!
That's exactly what I was going to suggest - the "default" settings don't work particularly well because they're just not set with a .4mm nozzle in mind, so you'll need to adjust them before making your first prints - most notably the things that will trip you up and cause major print problems are the nozzle size and the layer height, but the default speeds are all too high for a stock simple as well so you'll want to dial those back as well (see the simple settings thread for suggestions there). That said, my simple was surprisingly well calibrated right out of the box - make some calibration prints and make careful measurements, but if your printer is "pretty darn close" (say your 5mm calibration cube measures 25.17mm across), I wouldn't change anything.
sarahspins
