My (Fourth) Blob
My (Fourth) Blob
Postby mrflyer » 2014-Mar-Tue-20-Mar
Hey guys. I got my printrbot almost a month ago, but have only printed 4 parts. All of them have come out pretty well, until this one.
Any idea why it did this or how to fix it? Thanks in advance.
mrflyer
My (Fourth) Blob
Re: My (Fourth) Blob
Postby wasty » 2014-Mar-Wed-00-Mar
The motor which makes the move to the left/right is slipping. The gear wheel is slipping from the motor shaft...
wasty
Postby Stradawhovious » 2014-Mar-Wed-10-Mar
What machine do you have? What settings are you using to print?
If I had to guess you are running a simple at a feedrate of 100 and the fishing line used to move the x axis is loose.
Stradawhovious
Postby mrflyer » 2014-Mar-Wed-12-Mar
I'm using a simple made from the kit. Exxtruder temperature is 205. Can't really remember the other settings and I'm away from the computer I use to print right now. I'll look up the other settings when I get home. How could I fix the loose/slipping x axis?
mrflyer
Postby Stradawhovious » 2014-Mar-Wed-12-Mar
mrflyer wrote:I'm using a simple made from the kit. Exxtruder temperature is 205. Can't really remember the other settings and I'm away from the computer I use to print right now. I'll look up the other settings when I get home. How could I fix the loose/slipping x axis?
There should be a tensioner on one end of the x and y axis. On the X it's where the line is attached on the left side of the bed (as you look at the machine's front) and on the y axis it's in the back of the machine. Tighten the screw and the line will get taught. When you move the x or y axis all the way to one end and pluck the long side of the line it should be tight enough to produce a tone kind of like plucking a guitar string. My x axis line stretched (knots slipped) over the first week and was VERY loose. A couple turns of that screw and I was back in business.
I found mine loosened at the knot, so I would also recommend putting a tiny dab of CA glue on your knots to make sure they don't slip in the future. It may be overkill, but I also put a tiny drop of blue loctite on the nut at the tensioning screw.
Another thing you might consider (in addition to making sure the line is taught) is to back the feerate down to 75 or 80 to help keep the print motion less violent. I found that to keep the slipping to a minimum.
YMMV.
Stradawhovious
Postby slicedveggie » 2014-Mar-Wed-18-Mar
I had to tighten the crap out of my lines to prevent them from getting loose. Dont be afraid to use some force to tighten them. Also, 205 seems to be pretty hot for the PLA i've printed. I ended up turning down to 200 or even 195 for first and then 190 - 195 for additional and things got lots better for me.
slicedveggie
Postby mrflyer » 2014-Mar-Wed-20-Mar
So, I tightened the x axis. It doesn't seem to be slipping anymore, but I'm having this problem with the solid infill getting away from the perimeter on one side and into it on the other.
Any way to fix this?
I've got
.3mm layer height
25mm/s perimeter speed with 50mm/s infill speed.
I don't really know what other settings are important.
I'll turn down my temp.
Thanks for all the help so far!!!!! :D :D
mrflyer
Postby slicedveggie » 2014-Mar-Wed-20-Mar
Someone recommended these settings to me and for the most part they worked well, obviously you'll have to do your own tweaking, but in your case, i'd focus on the infill - viewtopic.php?f=113&t=3757&p=40996&hilit=simple+settings%3A#p40996
slicedveggie
Postby mrflyer » 2014-Mar-Thu-16-Mar
So I used those settings. Infill seems to be better, but I'm having trouble printing a part I designed. This is my design.
This is what came out.
As you can see slic3r is ignoring the empty space between the two vertical parts. I killed the print when I saw this. Do you guys know how to fix this?
Also kinda nit picky but is this jaggedness just an issue of calibration or something else?
Once again thanks for all the help
mrflyer
Postby RetireeJay » 2014-Mar-Thu-16-Mar
After you slice the object, you can look at it in Repetier using the "G-Code" tab to see if it sliced the way you want it.
Depending on what software you were using and your work method, the object that Slic3r saw might not be what you intended.
