rough bottom layer
rough bottom layer
Postby bmanbuff123 » 2014-Feb-Thu-13-Feb
Hi there, i recently got a new printrbot simple and have been doing a few prints. the top part of the print works great but the first parts is not. it comes out really bumpy and there are blobs everywhere.
bmanbuff123
rough bottom layer
Re: rough bottom layer
bmanbuff123
Postby wingedpower » 2014-Feb-Thu-14-Feb
Hmm... how is the clearance between the tip of the nozzle and the bed surface(with the tape)?
Looks like a combination of or either or of head dragging a bit or over extrusion?
wingedpower
Postby bmanbuff123 » 2014-Feb-Thu-14-Feb
So now it's only doing it to the front. The back is fine. It's just sloppy on the one side now.
bmanbuff123
Here is another photo [img]http://img.tapatalk.com/d/14/02/14/emabugez.jpg[/img]
bmanbuff123
Postby davec » 2014-Feb-Thu-16-Feb
Have you checked the reply to your other post? http://www.printrbottalk.com/forum/viewtopic.php?f=80&t=6337#p41101
davec
Postby bmanbuff123 » 2014-Feb-Thu-17-Feb
Yeh I tried that. Set it to 3. But still came out the same. The pic up top is what it looked like afterward
bmanbuff123
Postby bmanbuff123 » 2014-Feb-Thu-21-Feb
Thanks for all the help. I just got it working well now
bmanbuff123
Postby davec » 2014-Feb-Thu-21-Feb
What changes did you do to get it corrected? That way others with this problem can try that.
davec
Postby bmanbuff123 » 2014-Feb-Fri-07-Feb
I made the extruded just a little higher because it was rubbing on the last layer making it rough.
bmanbuff123
