Printrbot Talk Forum • View topic - My first blob / evenly spaced ridges?
Postby raimen » 2013-Sep-Fri-13-Sep
This was my first time printing with my Simple, and I am very happy with how it turned out, except for the ridges or lines that go across the print. If anybody can point me in the right direction to fix this, it would be supremely appreciated. :)
raimen
Re: My first blob / evenly spaced ridges?
Postby theshort » 2013-Sep-Fri-13-Sep
Did you design this? I would love to print one for my desk.
theshort
Postby Tdeagan » 2013-Sep-Fri-14-Sep
This is a Z-Axis effect. It's frequently caused by math. Really.
RetireeJay has done a fantastic writeup of this issue:
It's not impossible that it's mechanical, if the z threaded rod is wobbling badly, that could be the cause, but read the post above for the most likely cause.
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
Quick Change Extruders:
MIC-6 metal bed
Thingiverse Profile:
Tdeagan
Postby raimen » 2013-Sep-Fri-22-Sep
I did not design this, it was actually a featured model over on thingiverse, found here: thingiverse's thing:150212
Thank you for the replies! :)
I will be sure to check out the link when I get back! :)
raimen
Postby plexus » 2013-Sep-Sat-01-Sep
That amount of Z ribbing is more likely a bent or non-concentric Z threaded rod. the rods have to be straight and aligned as concentric with the coupler as possible. they should not turn and trace out a cone.
Postby Mooselake » 2013-Sep-Sat-11-Sep
The math thing, while it does exist, is often overstated and very subtle. It'll periodically insert an extra 1/2 of 1/1000 of a mm (one part per 2267.whatever), so your layers may vary from, say, 0.3000 to 0.3005 mm (or 0.0500 to 0.0505 if you're Plexus). Walking past, breathing on the print platform, or the cogging that happens when the Z motors are regularly switched off by the firmware will have at least as big an effect.
The ribbing in the photos is way more than that. Run the carriage all the way up to the top, loosen and carefully retighten the Z couplers and see if that helps - it'll help realign the screw straight in the coupler. Somebody on reprap.org suggested putting a BB between the motor and screw; if you're adventurous and try that report back.
