Printrbot Talk Forum • View topic - My First Print! - 5mm Cali. Cube on Printrbot Jr.
Postby mrsamnc » 2013-Aug-Sat-09-Aug
Well, here it is... the first print from my Printrbot Jr.! :D I'm very, very pleased with how it turned out. Perhaps lurking on here and reading as many threads as I could helped? Who knows, either way, I'm a happy camper.
5mm Calibration Cube ( http://www.thingiverse.com/thing:24238 )
I measured the cubes and they all were +/- .3mm of the expected 5mm size.
mrsamnc
Re: My First Print! - 5mm Cali. Cube on Printrbot Jr.
Postby RetireeJay » 2013-Aug-Sat-15-Aug
Great job, Mr Sam! :D
I'm glad the PB people recognized your need for the correct motors and responded in a reasonable time frame.
Postby ajb2189 » 2013-Aug-Tue-13-Aug
Wow, thats a great looking first print!
Do you have a fan on your Printrbot Jr?
ajb2189
Postby mrsamnc » 2013-Aug-Tue-13-Aug
Yep. It came with the Jr. kit from PBHQ. Thanks
mrsamnc
Postby Mochaboy » 2013-Aug-Tue-13-Aug
<slow deliberate clap rising to a crescendo>
I'm glad to see we didn't steer you wrong :)
Printrbot Jr born 6/13
Brass M8 Threaded Z Rod
Tool less belt tensioners
Aluminum print plate
Mochaboy
Print winner 1st
Print winner 1st
Postby mrsamnc » 2013-Aug-Tue-14-Aug
Oh gosh no... I'm very, very happy with my Jr! I've also much-enjoyed blowing the minds of my co-workers to explain to them that yes, there is such as thing as a 3D printer. :D
I must admit though.. I've already been looking at brass M8 and GT2 pulley upgrades. :P
mrsamnc
