Printrbot Talk Forum • View topic - It prints!
It prints!
It prints!
Postby thoughtfix » 2013-May-Sun-01-May
Okay so it is just a box. Still: major props to the board for all the tips here. Things I had to learn:
The included ABS wants to print at 230. Less than that and it will push too hard, jam the nozzle, then grind plastic into the grooves of the hobbed bolt.
Tension on the hobbed bolt was all guesswork.
That hairspray on Kapton on glass was magic.
Doing the "Paper slide test" on all four corners gives better balance and calibration.
Tomorrow I am starting to build an acrylic cat-resistant cover so I can do larger more elaborate sculptures.
thoughtfix
It prints!
Re: It prints!
Postby REPRAP SQUAD » 2013-Jun-Tue-13-Jun
Nice work, im glad we could get you up an running. The people on here have a wealth of knowledge and are always willing to help out a fellow Printrbotter.
