Machine: Printrbot Plus
Software: Cura 15.04, Repetier Host
I have the above setup that was passed down to me to get working. I guess it was working at one time, but then the extruder contacted the bed. It sat for a while until I decided to learn about it and get things going again.
I have many questions, so please be willing to read through.
I decided to start from scratch to make sure everything is working well. I uninstalled and reinstalled Cura 15.04 per the Printrbot Guides and Instructions. The Simple.Plus.GettingStartedProfile.ini was installed. Next, I opened the 3mmBox.stl and started to home the axes. In the Printrbot Auto Leveling Guide is states to “Turn both threaded rods (Z axis) counter clockwise until the end tip touches the print bed.
How do you know that you are turning the rods the same amount?
Anyway, I did my best to make sure it was level, dropped it to the bed, and adjusted the Auto Leveling Probe with the spacer and the wooden wrenches. This was the outcome of the print:
The extruder moved across the bed and then started dumping filament at this location. After hitting Emergency Stop, I raised the Z axis to the location in the photo.
Ok then, I’ll try Repetier Host. This program was already installed on the computer, so I opened the same 3mmBox.stl, sliced it, and printed. Although the extruder seems too high to print the leading square, it is mushing the actual print. These two operations seem to be opposite of each other.
Other questions:
1. Why are my prints going to the very top of the bed? Should they not be in the center? How do I fix this?
2. When I look at the bed settings. It always shows Home as the bottom left point, but when I home all axes, the extruder moves to the top left point. Is this correct?
Am I missing out on some vital information here? Still trying to wrap my head around this stuff. Thanks in advance for any help.
