by RetireeJay » 2016-Sep-Sat-17-Sep
The very first item in Cura's basic settings for Quality is layer height. Generally, you specify something between 0.5 to 0.85 of your nozzle diameter. Your nozzle is probably 0.4mm unless you've changed it yourself, so your layer height should be 0.2 to 0.34. Usually, we don't bother trying to make the layer thickness an exact integer divisor of the object's height.
On the other hand, it makes sense to specify the top and bottom fill thickness as an integral multiple of your layer thickness. So, for example, if you set your layer height at 0.25 you would tell the top and bottom "fill" thickness to be 0.5 or 0.75 or 1.0mm (2, 3, or 4 layers). If you specified 1.0mm, then that would mean your object would have 1mm at the bottom, then 1mm of lower-percentage "fill" and then 1mm solid on top. (The "Fill Density" is a percent that you'll get in that intermediate layer. But don't worry, the outer walls will be solid, not low-density.)
