by RetireeJay » 2016-Jul-Fri-20-Jul
If the printer didn't change, then it really must be in your settings somewhere.
Are you using the embedded Slic3r or Cura Engine in Repetier, or are you slicing separately? If you are using Slic3r, you can find text files with all of your settings under C:/Users/[yourname]/AppData/Roaming/Slic3r. There are three subdirectories there for Print, Filament, and Printer. Each subdirectory may have several files of settings. Find the files you are actually using (they will be identified in Repetier if you are using it to call Slic3r), open them in notepad, and copy-and-paste the contents into a post here. Preferably, use the "Code" button above the forum's editing box to "contain" each of these files (separately). Then we can examine your settings and see if something looks way off.
