First PB Play Prints!!!
Postby bigtime » 2016-Apr-Mon-08-Apr
Hi everyone!!,
This is my first post :D . I thought I would share a couple pictures of my very first, ever printed objects. I have never used a printer or even held a 3D printed object. I have to say after a couple of days of calibration and making 10 or so 3mm squares I am very impressed with the results. The first ever non-box object is the small Maker Bot and the second is the larger one. I used a stock .4mm tip, layer height is .1. Heated bed at 65C, hot-end is at 214C. All the other settings are default with the exception of the M212- Z adjustment. I found for my bot, -.95 worked the best. Let me know what you think!!
1505 Play
Y Axis Upgrade with Heated Bed
ultra ATX 750 watt modular power supply
bigtime
Re: First PB Play Prints!!!
Postby Mooselake » 2016-Apr-Mon-11-Apr
Nice! Congratulations!
What are you going to do when they jump off and try to take over the world? Looks like they're thinking about it :)
Postby bigtime » 2016-Apr-Mon-16-Apr
Can anyone suggest some setting changes to improve prints? I had a bit of a hard time breaking the joints loose. From the picture it looks a little sloppy in the inside. Maybe cooler hot end temp or slowdown the extruder?
1505 Play
bigtime
Postby plexus » 2016-Apr-Mon-20-Apr
This one is fun to print. I was able to get it working. you can try reducing the flow. i think my best print had a flow factor of 0.8 or 80% of normal. you can also reduce extrusion width and over-laps and other print "micro-structures". I use Kisslicer which has control of a lot of these physical parameters. I think it could be printed to be even looser but I didn't want to waste filament on that.
Postby bigtime » 2016-Apr-Tue-07-Apr
plexus,
Thanks for the reply. I will check out Kisslicer! I think my flow rate is at 100%. I'll give is a shot at 80%
1505 Play
bigtime
