by RetireeJay » 2016-Jan-Tue-20-Jan
This is happening because your Z-axis "endstop" switch (or sensor) is not being triggered at the right place. Does your printer have a bed-sensing probe beside the printhead, as seen in this photo of the metal Plus ? It's the silvery, threaded cylinder to the right of the hot end.
I imagine not, if you have an older Plus. In that case, your Z zero position is sensed by a "microswitch" that's probably located in the back left corner of the printer. There's a long screw which is supposed to push on the lever of the microswitch when the carriage gets down to the correct height. It's critical to get this adjustment exactly right. If the screw doesn't touch the microswitch soon enough, then the head ends up resting on the bed (and your "down" movement may go on for a long, long time). If the screw touches it too soon, then the nozzle won't be close enough to the bed to get good adhesion. If the microswitch is not positioned correctly, then it doesn't get actuated when it should.
By the way, any time the Z nuts come out of their "sockets" you need to re-check the "level" of the carriage. I do NOT mean level with a spirit level, I actually mean that the nozzle needs to maintain a constant distance away from the bed whether it's at the left or the right end of its travel. So check this and if the carriage is not parallel to the bed then turn one of the threaded Z rods by hand and check again until you have it parallel. Only after ensuring that the carriage is parallel should you proceed with adjusting the Z zero point. There are actually lots of threads mentioning the bed clearance, as well as instructions on Printrbot.com and in other forums. Good luck
-RJ
