Messed up date?!?
Messed up date?!?
Postby truehybridx » 2015-Feb-Thu-09-Feb
There seems to be something seriously wrong with the date on the forum :/
2 Examples:
On the board index my last visit was 2015-Feb-Wed-20-Feb and it says it is currently 2015-Feb-Thu-08-Feb (because time travel :D)
On my UC it says I joined yesterday: 2015-Feb-Wed-19-Feb and my last visit was 2015-Feb-Wed-20-Feb.
Any thoughts? It's kind of hard to find out the order of threads to read with dates like this :D
truehybridx
Messed up date?!?
Re: Messed up date?!?
Postby plexus » 2015-Feb-Thu-10-Feb
I know the first instinct is to post when you come across something that seems out of wack. but posting is not troubleshooting. its being lazy.
Use search first. you will find many posts from fellow lazy people like yourself and replies from less lazy users to point out how you could have fixed this yourself and saved us all the hassles of reading it.
Locked.
Postby RetireeJay » 2015-Feb-Thu-11-Feb
The solution is to go into your own settings.
User Control Panel -> Board Preferences -> Edit Global Settings -> My Date Format
I'm going to move this thread to General: Forum Talk and make it sticky.
Return to Forum talk
