Printrbot Talk Forum • View topic - Forum Dates incorrect ** FIXED **
Postby praedor » 2014-Mar-Sun-00-Mar
Hi Guys,
Noob here, this is my first post. I noticed that the DATE NOW on the Board Index Page says Sunday 5th March 2014, this is Sunday 9th March 2014 05:44 AM here in the UK, I know there are some time differences across the globe, but 4 days....LOL .
It gets worse though, apparently I can see posts that will be made several weeks from now, for example, there will be a post on Thursday 22nd March 2014 by MichaelD33 about infilling outside perimeters.
Has my laptop developed a spooky power or is there a problem with the forum and dates ?
PS I've checked my laptop and a couple of other forums I frequent, the problem only seems to be happening on this forum.
praedor
Re: Forum Dates incorrect
Postby evanalmighty » 2014-Mar-Sun-01-Mar
It's not just you. I tried changing my time zone in my profile and it doesn't work either.
evanalmighty
Postby praedor » 2014-Mar-Sun-01-Mar
Just noticed, that although we posted minutes apart, my post is dated 2014-Mar-Sun-05-Mar, yours appears on my system as 2014-Mar-Sun-06-Mar, system seems to like Sundays LOL.
praedor
Ooooops - Sorry folks, seems that you have to set correct info in User Control Panel/Board Preferences/My Date Format, change it from custom to one of the offered options.
Head Slap <<< Should have searched the forum before posting.
praedor
Re: Forum Dates incorrect ** FIXED **
Postby IncVoid » 2014-Jul-Mon-09-Jul
just saw this.
I wasn't here yesterday... so I figured its just an error that applies to the last post, and also maybe based on old cookies or something?
logged in.
got that..okay..4 days ago..I dont' remember, changed date settings..awww july1st..sounds about right...
could be intentional to make forums look "livelier"..or its just bad cookies being updated without being logged in or something I dunno.
IncVoid
Postby Mooselake » 2014-Jul-Mon-18-Jul
Nothing to do with cookies; the forum uses your user profile for the date conversion. Probably just some odd computer weirdity, or radiation :)
Postby IncVoid » 2014-Jul-Sat-04-Jul
But when not logged in, like using a public computer the dates look wrong.
IncVoid
Postby thawkins » 2014-Jul-Sat-06-Jul
Postby smohr » 2014-Jul-Tue-18-Jul
There's something wrong with the default date format for new users. The reply above mine was dated "2014-Jul-Sat-03-Jul". The previous one was "2014-Jul-Sat-01-Jul". July 3 was a Thursday and July 1 was a Tuesday, which makes me think it's emitting a day of the week and displaying it as the month or something like that.
The default in the user profile settings is set to Custom 'Y-M-D-H-M', which I guess isn't doing what you'd expect.
Is this a global problem or did I happen to create my account at a time when the global defaults were wrong?
smohr
Postby Extrudo » 2014-Sep-Fri-07-Sep
Seems to have been an issue for quite a while judging from posts above. Is there something I can do to fix it my end now, or is it an incorrect server-side setting? It makes searches challenging. :?
Extrudo
Postby dshook » 2015-May-Tue-18-May
The default for the profiles is really bad. Y-M-D-H-M means Year Month Date Hour Month.
A much better setting that I use is Y-M-d H:m
dshook
Postby Mooselake » 2015-May-Tue-19-May
Easy to change - User Control Panel, then Board Preferences tab, then use the pull down list. Your best setting is somebody else's worst setting...
Postby thawkins » 2015-May-Tue-21-May
Postby cacb » 2015-May-Wed-01-May
cacb
Postby PxT » 2015-May-Wed-08-May
@plexus is the only person who can fix this.
Postby Mooselake » 2015-May-Wed-08-May
Return to Forum talk
