Why are the post dates all screwed up?
Postby RudeJoe » 2013-Nov-Wed-11-Nov
I see I joined in the future and I see my posts are dated in the future. Is this a setting on my end or is something screwed up with the site? Thanks
RudeJoe
Re: Why are the post dates all screwed up?
Postby RetireeJay » 2013-Nov-Wed-13-Nov
Maybe it has something to do with your time zone. Or maybe it's the way your computer OS is interpreting the date information and displaying it on your screen. There are different conventions in different parts of the world for how dates are displayed. One would think that the underlying data would be consistent across all of the Internet, but maybe not always...
On my screen, your original post in this thread is showing 06 Nov 2013 12:01, which seems very reasonable.
(I'm running Windows 7, and using Firefox as my browser)
Postby ahaer » 2013-Nov-Wed-15-Nov
what I'm seeing
#1 by RudeJoe » 2013-Nov-Wed-11-Nov
#2 by RetireeJay » 2013-Nov-Wed-13-Nov
- 160mm Z axis (thing:215625)
- 190mm metal bed
- 160mm z travel
- 1U PC Power supply
ahaer
Postby ahaer » 2013-Nov-Wed-16-Nov
to fix click on "user control panel" (top left, under big red "printrbot") then pick "Board Preferences" tab then pick real value for "My Data Format"
When I went in there it was set to Custom... Now that I picked something from the drop down list it is correct...
- 190mm metal bed
- 160mm z travel
ahaer
Postby dragonflysg » 2013-Nov-Thu-06-Nov
thanks for the tip.. thought something wrong with the forum. so it was all just a setting issue.
Printrbot Jr V2 (now printing)
dragonflysg
Return to Forum talk
