clicing on link in email
Postby pomonabill221 » 2013-Aug-Sun-14-Aug
This has NOTHING to do with our printers, but when I receive an email from the board that a response was posted in a thread that I am watching (like this);
viewforum.php?f=85
when I click on the link, it takes me to the;
Board index ‹ General ‹ Welcome, introductions and stories
and not the particular thread.
Is this correct? I thought the link should take me to the thread directly.
I am on other boards and it does work this way, but not here.
Also, EVERY thread that I view, the second "post" is always an ad that is blank... is this the way the board works?
hhmmmm....
Bill
PBplus V2 kit.
* NOW with AUTOLEVEL!!!!
pomonabill221
Re: clicing on link in email
Postby allanonmage » 2013-Dec-Thu-12-Dec
I agree that this is a problem. So much so that I went back in time and created this thread:
viewtopic.php?f=7&t=2870
No, I dind't go back in time, I'm just joking. But I see this phenomenon has not been addressed/fixed yet, so I'm here to bump it up the totem pole of priority.
allanonmage
Layer 100 of 1234
pomonabill221 wrote:Also, EVERY thread that I view, the second "post" is always an ad that is blank... is this the way the board works?
Bill
That's your ad blocking software at work.
allanonmage
Layer 100 of 1234
Postby kuntalghosh » 2014-Apr-Thu-11-Apr
I don't face any problem even.
kuntalghosh
Return to Forum talk
