Printrbot Talk Forum • View topic - Why with the FILO of the imaging on the message boards???
Postby allanonmage » 2013-Jul-Tue-08-Jul
FILO -> First In Last Out
Why does the forum software do a reverse (FILO) sort on images that are loaded? It's REALLY annoying.
Can it be fixed, changed, or altered on a board or user level?
For example, check out the images loaded here. They are numbered and attached to this post in the order they represent themselves.
Started with a Printrbot LC Kit; now it's a monster as big as a mid size fridge!
Single ATX Power supply, 650 watts, relay controlled heat bed
extra Z height (3+ ft) via longer rods, but I don't use it. Yet. To reduce wobble, I'm using thing:46082 under the Printrbot.
Dual heated beds, 1 currently working; space for a 3rd
Purple gluestick on glass seems to be sticky enough to get adhesion
FB album with pics: https://www.facebook.com/media/set/?set ... ec287e8726
This was supposed to be a tool, not a series of projects... grrrrr......
allanonmage
Layer 100 of 1234
Re: Why with the FILO of the imaging on the message boards??
Postby RetireeJay » 2013-Jul-Tue-09-Jul
If you "Upload Attachment" and then "Place Inline" you can control where your picture shows up.
The above picture was inserted where I wanted it into this very message, and here's what it looked like on my screen while I was inserting it. After Uploading, I placed the cursor where I wanted the picture and I clicked on "Place Inline" which resulted in the "attachment.../attachment" line. You can simply cut and paste this line wherever you want it in the message text - and verify it looks like what you want by using the Preview button.
Postby allanonmage » 2013-Jul-Tue-09-Jul
Ohhhh.... well that makes sense
allanonmage
Layer 100 of 1234
Return to Forum talk
