by RetireeJay » 2013-Jul-Tue-09-Jul
If you "Upload Attachment" and then "Place Inline" you can control where your picture shows up.
The above picture was inserted where I wanted it into this very message, and here's what it looked like on my screen while I was inserting it. After Uploading, I placed the cursor where I wanted the picture and I clicked on "Place Inline" which resulted in the "attachment.../attachment" line. You can simply cut and paste this line wherever you want it in the message text - and verify it looks like what you want by using the Preview button.
