Printrbot Talk Forum • View topic - Printrbottalk wiki
Printrbottalk wiki
Printrbottalk wiki
Postby plexus » 2012-Oct-Sun-19-Oct
Printrbottalk wiki
Re: Printrbottalk wiki
Postby carlos » 2015-Jul-Thu-20-Jul
Not sure if it's been noticed, but it seems the wiki software is having issues, can't access most of the site.
Printrbot Simple Metal (using Rev F board) with E3D hot-end and heated bed.
carlos
Postby 2Mylent » 2015-Jul-Sat-06-Jul
Wiki does not work (see attached image) :!:
Printrbot Simle Metal + Upgrade Heatbed / Upgrade E3D v6 / Simplify3D / Win7 64bits
FRANCE
2Mylent
Postby plexus » 2015-Jul-Tue-18-Jul
Sorry about the wiki, folks. the software used for the wiki (mediawiki) and the forum (phpBB) are serious server side solutions which have a brain dead admin interface. you basically have to be a sys admin to be able to do anything other than basic things. i find they are both very fragile packages and that any small thing can take them down. then good luck trying to get through the weeds of all the files and php. if you are a sys admin with expertise in php then you can fix things. but if not (like me) its an uphill battle.
Apparently the ISP did some server software upgrade which triggered a bug in mediawiki. the solution is to upgrade it. but i have found (the hard way) that doing an upgrade can cause a critical failure. this happened a few time with the forum in the early days. now i don't mess with it. i tried an upgrade on the wiki and its still broken.
I just don't have the expertise to fix it. i also don't have the time to become an expert so I can fix it. such is the plight of open source software (i dont really like open source stuff for these reasons).
so there it is. sorry.
Postby RetireeJay » 2015-Jul-Tue-20-Jul
And by the way, formatting code to look good as presented on-screen by the wiki is a bit of a challenge (at least for someone who has never programmed in php or html).
Postby plexus » 2015-Jul-Wed-10-Jul
Postby plexus » 2015-Jul-Wed-16-Jul
Thanks to PxT for helping me fix it. I've installed the latest wiki version as well. everything should be as normal but please if you find anything that isn't right please PM me about it with details. thanks!
  • 3
Return to Forum talk
