Email Registration Not Working?
Postby duk2422 » 2012-Aug-Sat-05-Aug
I tried to sign up to this forum with a few different email addresses and it wouldn't let me, in the end I used an old gmail account for it to let me on.
Is there restrictions about allowing emails to sign up?
The domains I tried were duklabs.com and my work catholic.edu.au address...
Thanks,
Ducky
duk2422
Re: Email Registration Not Working?
Postby plexus » 2012-Aug-Sat-11-Aug
what error did you get? there are no specific domains that where manually blocked but its possible phpbb has some kind of automatically configured blocking.
Postby duk2422 » 2012-Aug-Sat-17-Aug
plexus wrote:what error did you get? there are no specific domains that where manually blocked but its possible phpbb has some kind of automatically configured blocking.
None, the emails just never turned up. It said it had sent the email off too (I even tried the resend activation email thing, still nothing).
The duklabs.com one is a redirected email that goes to a gmail account (the same gmail account that when used directly works).
The other issue was trying to get in contact with you so I could get my account activated :P I just couldn't find any sort of contact for you other than this forum anywhere D: (though if I did find it, it would be kind of creepy in a stalkerish way).
I'm just hoping that no one else is having the same problem..
Thanks,
Ducky
duk2422
Postby jamblor47 » 2013-Sep-Mon-19-Sep
Just had a similar problem trying to register for the forums using a hotmail account.
No activation email was sent. Waited a few hours, resent the activation email, nothing. Said to contact an admin but the only way to do that is by logging in to the forum...
Any who, here now :)
jamblor47
Postby Porter » 2013-Oct-Mon-20-Oct
Just some feedback, I also had a similar issue. I registered on a Friday and it said there would be an activation email sent, which I never received (email was to my own domain). On Monday, I tried signing in and it said that I hadn't been activated and gave me the option to resend the activation email. As soon as I clicked on the resend, I received an email and was able to access the forum after that.
Daniel
Porter
Postby runcible-jack » 2013-Dec-Sun-16-Dec
I got tired of waiting for somebody to respond and or fix this problem and just used another e-mail address. I tried to file a problem a week ago and I get that they are busy, but if people cannot get access to the community to ask for help in solving their own problems for over a week because some glitch refuses to send e-mails to confirm then somebody should change forum protocols to allow guest responses to posts and open a topic for them to reply to in order to get help in resolving these things.
otherwise it starts to look like "got your money, don't care". Which I don't think is how people here actually feel and would be a shame if that's the message they inadvertantly send.
runcible-jack
Postby RetireeJay » 2013-Dec-Sun-16-Dec
The Printrbottalk forum is staffed by volunteers who like to help people. PBHQ does not run it.
Postby plexus » 2013-Dec-Tue-21-Dec
runcible-jack wrote:I got tired of waiting for somebody to respond and or fix this problem and just used another e-mail address. I tried to file a problem a week ago and I get that they are busy, but if people cannot get access to the community to ask for help in solving their own problems for over a week because some glitch refuses to send e-mails to confirm then somebody should change forum protocols to allow guest responses to posts and open a topic for them to reply to in order to get help in resolving these things.
I don't have anyone's money. but if you want to send me some...
Postby Corey Warren » 2014-Feb-Wed-14-Feb
I just had the same issue with two different hotmail accounts. I never received the email notification. I had to use a gmail account. I would love to edit my email address as I hardly ever use this one, but, it won't let me telling me that email address is already in use. Is there a way to delete my old attempts at registering? I would list my email addresses but, it considers there off-site URLs and its "too spamy for a new user."
Corey Warren
Postby copshop » 2014-Apr-Tue-19-Apr
Me too ! I had two failed registrations using comcast accounts. Never got the authentication email. Tried to resend - nothing. I am currently logged in through my work email system, which I can not keep using.
Could an admin PLEASE check my preferred account and authenticate it or see why it wont send to:
User: mcdeal
If you need more info, let me know.....
Thanks
Waiting on the UPS truck . . . .
copshop
Postby kuntalghosh » 2014-Apr-Thu-11-Apr
I able to signup with my gmail id. I don't faced any problems
kuntalghosh
Postby altan86 » 2014-Apr-Tue-04-Apr
Hey everyone, just registered today with my gmail account. I tried my hotmail email earlier but I also did not received the activation email.
This seems to be some sort of recurring problem with hotmail account. So for new users unable to login or received the activation email, try using your google email instead.
altan86
Return to Forum talk
