Printrbot Talk Forum • View topic - Printrbot Original
Printrbot Original
Printrbot Original
Postby Msmaster321 » 2016-Oct-Tue-13-Oct
Hey guys I'm new to the 3d printing world and this site. So long story short I bought a printrbot original the one from the 2011 kickstarter from a guy on eBay cause I thought it was a great deal and I wanted to get into 3d printing. When it arrived I had assembled it but it never came with a board i finally found a file for the board and ordered it through Ponoko, it should be coming in next week. Before that I had a temporary board that I cut and mounted the bed to it. I installed pronterface and cura for the g codes and I learned how to configure the steps per millimeter and everything but when I hit print the printer basically made a blob I found out that i need the newest software and when I looked in the github for printrbot there was not any thing that said for rev b boards. Can someone tell me where I can find the file and also where I can get the springs for leveling the bed. Thanks
Msmaster321
Printrbot Original
Re: Printrbot Original
Postby RetireeJay » 2016-Oct-Tue-21-Oct
Postby Mooselake » 2016-Oct-Tue-21-Oct
Blobs are traditional. There's even a first blob section of the forum to post pictures of them. Go take a look, particularly of the old entries.
Return to Forum talk
