Tap, tap, is this thing working?
Postby frankv » 2016-Jun-Mon-16-Jun
No new posts for a couple of days... surely something has gone wrong?
Re: Tap, tap, is this thing working?
Postby RetireeJay » 2016-Jun-Mon-16-Jun
I guess all the questions are answered already! :D
Postby Mooselake » 2016-Jun-Mon-17-Jun
Everybody spent the weekend at amateur radio field day, and is recovering? The thunderstorms (2"/5cm of rain in two hours) helped me find the one remaining small leak in the hamper roof.
I monitor a number of groups, er communities, on G+, and they didn't have any posts over the weekend either.
Return to Forum talk
