Minimum no of characters in a post
Postby RetireeJay » 2019-Jan-Thu-11-Jan
I've changed the minimum number of characters for a post to 5. It had been 25, which often seemed to be an annoyance.
Re: Minimum no of characters in a post
Postby novice » 2019-Jan-Thu-12-Jan
Thanks
Return to Forum talk
