Printrbot Talk Forum • View topic - Ars Technica article about 3D printers
Discuss and document interesting online resources like projects, blogs, articles, data sheets, product info, shops, etc. an online repository of Printrbot related of interest info
Postby bburnett » 2013-Aug-Wed-09-Aug
For anyone that hasn't seen the article on Ars Technica about the Printrbot Simple and the replicator should take a look at; pretty good read!
http://arstechnica.com/gadgets/2013/08/ ... dimension/
bburnett
Re: Ars Technica article about 3D printers
Postby halley » 2013-Aug-Wed-12-Aug
There is definitely a hype-vs-reality problem in 3D printing. The high-end proprietary filament printers have just as many problems (just different problems) as the low-end string-drive models. Add to that a user who describes their mechanical prowess at the "assembles Ikea" level, you're going to have challenges. Many tinkerers overcome the challenges, but quite a few don't. We've had some newbies come onto this forum and basically rage-quit when they couldn't print the Yoda head within the first few days.
halley
Postby jafenske » 2013-Aug-Wed-13-Aug
My printrbot plus V1, after assembly, was not ready to print. It took quite a bit of troubleshooting and tinkering to get good quality prints. For me that continues to be part of the fun. I would also like to say that Brooke's comment at the end of the article is very classy.
jafenske
Postby rho-wan » 2013-Aug-Wed-15-Aug
It should be pointed out that the Simple, it seems, has more issues than a LCv2 or Plus v2, he could have gotten better results, but still… I also expected the printer to work easier than I experienced.
rho-wan
Postby DonaldJ » 2013-Aug-Wed-20-Aug
DonaldJ
Postby Mooselake » 2013-Oct-Tue-23-Oct
I'm a bit behind...
This article has one of the greatest descriptions of 3D printers I've found "a pit without a bottom—an absolute yawning Stygian abyss of options and tweaking and modifications and endless re-printing".
That must be why we like them so much :-)
Postby russellriker » 2015-Sep-Wed-09-Sep
great read. wish I could write like that. And Brook's comment at the end was classy. But as a video I saw that Brook created. "3d printing is hard". very true statement that I'm learning every day with my new little Printrbot Metal Simple.... but I still love my little printer.
-Russ
russellriker
Return to Online resources
