Loading Up the Y Arm?
Postby the.ronin » 2015-Mar-Mon-10-Mar
I had planned to install some 40mm motors to cool the motors. I was considering mounting the fans meant to cool the Y and extruder motors onto the Y arm itself when it occurred to me that I'd be placing some additional load on that arm. I considered mounting the fans on the base but for tall prints, the Y and extruder motors would get way out of reach of the fans. Is it ill advised to add load to the Y arm in that it might effect print quality? Just a couple 40mm fans, some custom designed mounting, and the wires.
the.ronin
Re: Loading Up the Y Arm?
Postby orangefurball » 2015-Mar-Mon-15-Mar
How heavy are the fans?
They shouldn't effect it. I used to run 3 fans on my wood Simple and some run a GoPro on the Y axis of the metal Simple. Either way you shouldn't have any issues!
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Postby the.ronin » 2015-Mar-Mon-15-Mar
A Gopro! Wow thats very heavy! Thanks so much for your feedback.
the.ronin
Return to Assembly talk
