Printrbot Talk Forum • View topic - [Solved] Simple Metal works; Upgraded to heated bed won't t
Postby Stirling » 2015-Jan-Sat-12-Jan
I tested the simple metal without heated bed and it worked fine. I'm attempting to upgrade with the printrbot heated bed and it won't turn on now.
This is my power supply specs from EVGA, 430W, supports 12V: EVGA.png
It does not have a switch like the one printrbot provides for the US/EU voltage conversion
PCI-E 6+2 - reading the forums tells me this shouldn't be an issue. I don't have a Y-cable, but that also shouldn't be an issues
There is no extension cable so the positioning should be the same for the other thermistor. Thermistor for heated bed:
There were only 2 stripped wires for the screw terminals, 1 red, and 1 black:
I'm at a loss. Have been looking around the forums all day for similar problems. Any help is appreciated.
Stirling
Re: Simple Metal works; Upgraded to heated bed won't turn on
Postby RetireeJay » 2015-Jan-Sat-14-Jan
ATX supplies often have a green wire that's used to control the power (it's a logic-level input to the power supply). You need to ground the green wire by connecting it to a black wire to get the ATX supply to fully turn on.
Other than that, you hookup looks good. You have a Rev F board, which does not use the power supply Y adapter, and your use of the stripped wires from the heated bed going in to the screw-actuated terminal strip is absolutely correct.
Postby Stirling » 2015-Jan-Sat-19-Jan
Thank you! That was the exact problem. Really appreciate your response.
Stirling
Re: [Solved] Simple Metal works; Upgraded to heated bed won'
Postby braden » 2017-Jun-Thu-00-Jun
Same issue. I had my atx working fine for months. Turned if off for a while, then wouldn't work again. I assumed the ATX went bad. Replaced it and am now using a Rev F but I can't get the ATX fan to even spin. What green wire to what black wire?
braden
Postby RetireeJay » 2017-Jun-Thu-06-Jun
This post has a picture of how I did it.
viewtopic.php?f=80&t=11351&p=72923&hilit=green+wire+ATX#p72923
Basically, you can only find one green wire coming out of an ATX supply. And all the black wires are ground.
Return to Assembly talk
