LC Kit - Which direction is X and which is Y?
Postby allanonmage » 2013-Feb-Sat-17-Feb
The only reason I know what Z is is because it has 2 motors. My initial thought was that the Z axis was Y, so obviously any guess on my part is not going to be accurate.
I'm trying to get my kit wired up and I'm not sure where to plug in a few of the parts. I found this:
http://help.printrbot.com/Guide/Printrb ... matic/15/1
and I've goten all but the last 2 motors and end stops connected.
Started with a Printrbot LC Kit; now it's a monster as big as a mid size fridge!
Single ATX Power supply, 650 watts, relay controlled heat bed
extra Z height (3+ ft) via longer rods, but I don't use it. Yet. To reduce wobble, I'm using thing:46082 under the Printrbot.
Dual heated beds, 1 currently working; space for a 3rd
Purple gluestick on glass seems to be sticky enough to get adhesion
FB album with pics: https://www.facebook.com/media/set/?set ... ec287e8726
This was supposed to be a tool, not a series of projects... grrrrr......
allanonmage
Layer 100 of 1234
Re: LC Kit - Which direction is X and which is Y?
Postby eckerput » 2013-Feb-Sat-17-Feb
Y is forward and back (movement of the heated base)
X is left and right (movement of the printhead)
Printrbot LC (November 2012)
+ Bed Leveler, Bed Stabilizer, Y Belt Tensioner
Thingiverse Profile
eckerput
Postby halley » 2013-Feb-Sat-21-Feb
halley
Postby allanonmage » 2013-Feb-Sat-22-Feb
Sweet thanks for the pic! That's awesome!
allanonmage
Layer 100 of 1234
Return to Assembly talk
