LC Kit - Which direction is X and which is Y?
Postby allanonmage » 2013-Feb-Sat-17-Feb
The only reason I know what Z is is because it has 2 motors. My initial thought was that the Z axis was Y, so obviously any guess on my part is not going to be accurate.
I'm trying to get my kit wired up and I'm not sure where to plug in a few of the parts. I found this:
http://help.printrbot.com/Guide/Printrb ... matic/15/1
and I've goten all but the last 2 motors and end stops connected.
allanonmage
Layer 100 of 1234
Re: LC Kit - Which direction is X and which is Y?
Postby eckerput » 2013-Feb-Sat-17-Feb
Y is forward and back (movement of the heated base)
X is left and right (movement of the printhead)
Printrbot LC (November 2012)
Thingiverse Profile
eckerput
Postby halley » 2013-Feb-Sat-21-Feb
halley
Postby allanonmage » 2013-Feb-Sat-22-Feb
Sweet thanks for the pic! That's awesome!
allanonmage
Layer 100 of 1234
Return to Assembly talk
