LC Kit - Some pics of the base as i was assembling it.
Postby allanonmage » 2013-Jan-Wed-09-Jan
So this is my first printrbot build and I didn't find many pics of the base from different angles. It was hard to judge what details were important and what weren't based on Brook's videos, and his order of assembly is NOT optimal, lol Kudos for doing them, I can only imagine the support will get better, but right now it needs some work.
So, if perchance you're reading this before assembly, do not put the board in at the time that he does in the video, skip ahead a little bit to the end stop, do that first, then to the board. It'll save you a bit of aggravation.
Also, put the base legs on before putting in the outermost motors. I had to re-do that like 3 times to get the proper order of things. It's not so much the time as the aggravation that bothered me.
Without further ado, here are some pics.
allanonmage
Layer 100 of 1234
Re: LC Kit - Some pics of the base as i was assembling it.
Postby chris » 2013-Mar-Fri-03-Mar
Good job, I'm still trying to get through it. It is really amazing and cool the way all these pieces fit together - it seems much stronger than I was guessing it would be. Although I'm still worried about the longevity of the zip ties, especially on some of the hard to see/notice areas...
It's been fun learning 123d also. Can't wait to get started printing stuff - I should probably order a mass of cheap abs spools so I don't run out when I can actually make some things...
chris
Postby allanonmage » 2013-Mar-Fri-04-Mar
Zip ties are almost immortal. I have a few holding key parts of my truck together. For example the gas pedal linkage to the mount on the carb
allanonmage
Layer 100 of 1234
Return to Assembly talk
Users browsing this forum: Google [Bot] and 1 guest
