How to set the current limits correctly
Postby erl » 2012-Dec-Thu-16-Dec
If you have a multimeter, you can set your current limiting potentiometers to the theoretically correct values for the stepper motors by connecting your multimeter ground (black) probe to one of the unused connectors with black wires going from the power supply to the PrintrBoard, and measuring with the multimeter's positive probe at the potentiometer terminals shown in the PrintrBoard image below (red, X, should be 440 mV, yellow (Y and E) should be 400 mV, blue (Z) should be 825 mV:
Works for me, and the motors run without getting too hot.
The background for those interested
The Printrbot X, Y and E stepper motors are according to the bill of materials here of type 42BYGH4807. The Z steppers are of type 42BYGH011.
The X, Y, and E stepper datasheet specifies their current as 500 mA per phase. The Z stepper datasheet lists the current as 330 mA.
The PrintrBoard uses Allegro A4982 stepper motor drivers. The datasheet says that:
The maximum value of current limiting is set by the selection of RSx and the voltage at the VREF pin. The transconductance function is approximated by the maximum value of current limiting, ITripMAX (A), which is set by
ITripMAX = VREF / ( 8 * RS)
where RS is the resistance of the sense resistor (Ω) and VREF is the input voltage on the REF pin (V).
The sense resistors (RS) of the PrintrBoard (except for the X stepps for some reason) are 0.1Ω, and VREF is set by the pontentiometer. For the X, Y, and E steppers, we want an ITripMAX of 500 mA. Solving the equation gives a VREF of 0.4V for Y and E, and 0.44 V for X
For the Z steppers, we have two steppers each wanting 330 mA, which gives us an ITripMAX of 660 mA. This gives us a VREF of 0.66 / (0.8) = 825 mV (0.825 V).
Good luck, have fun!
  • 3
erl
Re: How to set the current limits correctly
Postby lwalkera » 2012-Dec-Thu-16-Dec
All of the stepper drivers should have the same sense resistors. If you don't then your PB is defective or was assembled incorrectly.
Laine Walker-Avina
lwalkera
Postby erl » 2012-Dec-Fri-05-Dec
lwalkera wrote:All of the stepper drivers should have the same sense resistors. If you don't then your PB is defective or was assembled incorrectly.
I have not measured my resistors; I went by the schematic here (linked from the RepRap PrintrBoard Wiki page) which shows R17 and R18 (X current sense resistors) as 0.11Ω, and R16, R19, R24, R25, R30 and R31 (Y, Z, and E) as 0.1Ω. That is the Rev B version, I guess I should check the Rev D.
In any case, I don't think a 10% deviation will be very important.
Do you know what the actual resistor values are?
/Erland
erl
Postby lwalkera » 2012-Dec-Mon-13-Dec
They should all be the following or similar: http://www.digikey.com/product-search/e ... S.11FCT-ND The values on the schematic are mainly for indication, the actual values used are on the BoM here: https://docs.google.com/spreadsheet/ccc ... 3FLb3dmTUE
Laine Walker-Avina
lwalkera
Postby Alexcheve » 2013-Jan-Wed-16-Jan
My Printrbot plus kit came with five motors all with same numbers, I received it a couple of weeks ago. I have seen other posts suggesting to turn all potentiometers counterclockwise to "four oclock" but since I have not been able to print a thing mine are quite cold for the moment. And motor cable connectors can connect in both directions to board so it is difficult to find the right side.
Have Printrbot+ kit struggling assembly from January 12 to 18, use ABS for now. Cracked glass with three bolts with strings at HotBed. Am not able to print a thing yet but getting closer thanks to you.
Alexcheve
Postby jeromedayton » 2014-Jan-Sun-06-Jan
I've read elsewhere to not use conductive tools to adjust the pots as you might short some pins. So I ordered nylon tools, "anti static alignment tool kit", from GC Electronics and discovered that they are made of "conductive nylon" to deal with possible static on the board. So have I ordered the wrong kind of tool?
Jerome
Retired Software Developer
Printrbot Simple operational since Xmas 2013
Printrbot Jr v 2 with alu extruder March 2014
jeromedayton
Postby RetireeJay » 2014-Jan-Sun-07-Jan
The "conductive" feature for anti-static actually means resistance in the megohms, not ohms, so you should be fine. Or, you can make adjustments with the power off if you really want to be careful.
Postby REPRAP SQUAD » 2014-Jan-Mon-11-Jan
Alexcheve wrote:My Printrbot plus kit came with five motors all with same numbers, I received it a couple of weeks ago. I have seen other posts suggesting to turn all potentiometers counterclockwise to "four oclock" but since I have not been able to print a thing mine are quite cold for the moment. And motor cable connectors can connect in both directions to board so it is difficult to find the right side.
There are lots of diagrams etc that show motor plug direction etc. The 12o clock setting that comes stock is a good place to start but some fine tuning will help your motors run to the best of their abilities. I've turned some down and some up but all of my motors run nice and cool.
http://www.enviousmods.com
Postby Hadesblue » 2014-Feb-Sun-23-Feb
my pots are way off, reading from the left.
786mv, 825mv, 1137mv, 1111mv
Hadesblue
Postby Hadesblue » 2014-Feb-Wed-21-Feb
just for reference purposes this is what happens when the current limit is too low, and steps get skipped. I had to increase Y slightly higher than 400mv, probably because I'm using the aluminum build plate and it needed more power.
Hadesblue
Postby H315M4N » 2014-Apr-Tue-07-Apr
I'm glad I found this post. Instead of measuring 440, 400, 825, 400 mV across the four pots, I was measuring 850, 650, 1450, & 1425 mV. No wonder my motors got so warm! It runs quite a bit quieter now, too.
H315M4N
Return to Assembly talk
