Printrbot model 3 kit assembly information
Postby HAMADY263 » 2018-Sep-Tue-06-Sep
I have bought a printrbot model 3 kit last month , but when I received it there was no manual or any information on how to assemble and operate it . I searched online for long time but no luck. Any one has any information please let me know. attached is a photo of the same model
Regards
Adel
HAMADY263
Re: Printrbot model 3 kit assembly information
Postby RetireeJay » 2018-Sep-Tue-10-Sep
I never knew Printrbot made a CoreXY printer! But evidently they did. No one on this forum has ever discussed the Model 3 before. But there's a person going by the Thingiverse handle of "ururk" who has one, and he/she designed some improvement parts that are posted there; maybe you can find a way to get in touch with that person and see if they can point you to resources for building and commissioning the printer. https://www.thingiverse.com/thing:2772473
Postby HAMADY263 » 2018-Sep-Wed-01-Sep
Thanks RetireeJay for the information.
HAMADY263
Return to Assembly talk
