Metal Plus with G2 board
Postby Old Man Printing » 2018-Jul-Sun-07-Jul
I kind of feel like someone on an island throwing a bottle in the water with a note hoping someone finds it but here goes.
I wanted to upgrade my hot end to a ubis 13S so I also purchased the G2 board. I admit I did not pay attention to the statement "for the brave tinkerer".
So long story short here is my problem I can't get it to work. I have tried Cura, Octoprint and Repetier. I can manually move the nozzle and get it to heat up and extrude. What I can't do is get it to home or print. When I try to home it does not stop just grinds the belt. I am confident there are people out there that have done this successfully. Any help, guidance or direction would be great. If I can't get this to run my only alternative is to tell my wife that I failed and need to buy a different board. That would not be an enjoyable conversation. Thanks in advance for any help you can give.
Old Man Printing
Re: Metal Plus with G2 board
Postby ChefScott » 2018-Jul-Sun-14-Jul
You might want to flip the motor connectors that should get the motors going towards the limit switches and not away from them when you issue a home command. But don't flip the extruder connector, from what you are saying you are able to extrude plastic.
ChefScott
Postby Old Man Printing » 2018-Jul-Mon-22-Jul
My motors are all going in the correct direction.
Old Man Printing
Postby ktfergus » 2018-Jul-Thu-19-Jul
I'm not brave enough to try switching to a G2, but here's a thread which might have some relevant info: http://www.printrbottalk.com/forum/viewtopic.php?t=11357
It's from a year ago, so some of the problems may have been corrected, but it might be a good place to start...
-Kelly
ktfergus
Return to Assembly talk
