Printrbot Talk Forum • View topic - Filament diameter
Filament diameter
Filament diameter
Postby bres55 » 2014-Mar-Thu-06-Mar
I am just about to purchase some PLA Ø 1.75 mm blue 1 kg filament for 3D printer, the supplier states
Filament diameter: 1.75mm ±0.1mm
is this an acceptable tolerance, or should I pay more for better quality?
bres55
Filament diameter
Re: Filament diameter
Postby RetireeJay » 2014-Mar-Thu-08-Mar
Always measure the filament you get, and put that size into your slicing program. The only possible problem you could run into is if the filament is so badly oversized that it can't fit into the throat of the hot end - and that's extremely unlikely.
Postby PxT » 2014-Mar-Thu-12-Mar
±0.1mm tolerance is a typical value for a lot of suppliers, and from what I have seen they often advertise the same error margin for both 1.75 & 3mm filament. Keep in mind that given the same millimeter difference, the percentage error is doubled for 1.75mm filament compared to 3mm. This might be a point to support plexus' for using 3mm filament.
Protoparadigm has an in-depth article on the subject of filament tolerance: http://www.protoparadigm.com/blog/2011/ ... t-quality/
Incidentally, they advertise a .05mm tolerance for their filament (both 3mm & 1.75).
But to answer the question… I have not run into any significant problems that I could attribute to filament tolerance. In general, unless your machine is exceedingly well calibrated, other errors and small inaccuracies in positioning and repeatability are going to be more significant.
Postby bres55 » 2014-Mar-Fri-05-Mar
Thanks guys.
I've ordered it with Amazon co uk.
£19.90 inclusive.
I'm thinking it'll be ok to start with.
I was eager to have some at home when I get my Simple this Saturday.
I shall be going to the RobboSavvy course in London, we build it in the morning, and do all the rest
in the afternoon, caliibrate, SW etc.
I feel I could have built it at home, but was keen to meet up with other enthusiasts.
I'll do a review of the course next week some time.
bres55
Postby he3d » 2014-Jun-Mon-22-Jun
Blue, 1 kg, 1.75 mm, completely no problem, we can cooperation,
if you buy more, we can give you a discount and free shipping.
We have all the colors, can let you choose, look forward to cooperation with you.
http://www.reprap.cn skype:reprap.cn
he3d
Return to Buying
