Printrbot Talk Forum • View topic - Newbie...
Newbie...
Newbie...
Postby eskeyaar » 2013-Dec-Fri-10-Dec
Hi guys,
Will you ship printrbot simple assembly kit to india?
Do they include all electrical items?
Do they include the chemical filament?
Does it take more time to build because i am completely a newbie in this field, we have 3 cnc routers.
Any email to contact about shipping and other infos?
Thanks
Santosh
eskeyaar
Newbie...
Re: Newbie...
Postby REPRAP SQUAD » 2013-Dec-Fri-15-Dec
Re: Newbie...
Postby eskeyaar » 2013-Dec-Sat-23-Dec
Thankyou reprap squad.
can I make use of acrylic sheets instead of wood ??
I have laser cutting machine.so I can try different one??
thanks
Santosh
eskeyaar
Re: Newbie...
Postby REPRAP SQUAD » 2013-Dec-Sun-10-Dec
I've seen a couple acrylic printrbots so it is possible to do.
Re: Newbie...
Postby eskeyaar » 2013-Dec-Mon-00-Dec
Thankyou. Today i will cut the parts in acrylic and see..
Actually I tweeted to @printrbot somedays ago, but no response... :(
eskeyaar
Re: Newbie...
Postby REPRAP SQUAD » 2013-Dec-Mon-17-Dec
I might be able to put you in touch with a guy that cut his simple out of acrylic if it would be helpful to you. Happy building buddy.
Re: Newbie...
Postby eskeyaar » 2013-Dec-Mon-23-Dec
Thanks Reprap Sqaud, we have laser cutting machine so i can manage,
Just a clarification, should i cut in the shape of hexagon nut in acrylic or just this enough in attached picture??
Also 6mm acrylic will be suitable?
Difference b/w printrbot simple kit and printrbot with large motor? really confused.. :?
cheers,
Santosh
eskeyaar
Re: Newbie...
Postby PxT » 2013-Dec-Mon-23-Dec
Brook made one in red acrylic which looks really nice:
However he told me that the problem with acrylic is that it is brittle. Apparently he accidentally dropped the printer a few inches and the bottom shattered. Be careful…
Re: Newbie...
Postby REPRAP SQUAD » 2013-Dec-Tue-11-Dec
It should be how you have it now unless the design changed. I would leave it round as I can't see any advantage to cutting nut traps. Good work buddy.
Re: Newbie...
Postby eskeyaar » 2013-Dec-Wed-00-Dec
Thanks Pxt. Yes, it will reduce the strength. Going to make in wood.
Reprap sqaud, Thanks for your valuable info. i successfully placed Simple Builders kit today.
I don't get any reply from twitter, Feeling disappointed! but got reply from david last night. :-)
Santosh
eskeyaar
Re: Newbie...
Postby eskeyaar » 2013-Dec-Sun-10-Dec
Does anyone knows what is acme rod?? And smooth rod??
all rods are SS ? Any grade for them??
eskeyaar
Re: Newbie...
Postby eskeyaar » 2013-Dec-Wed-02-Dec
eskeyaar
Re: Newbie...
Postby thawkins » 2013-Dec-Wed-06-Dec
acme rod is threaded rod made by a company called ACME, smooth rod is just cold rolled SS rods usually 8mm or 10mm in diameter.
Re: Newbie...
Postby eskeyaar » 2013-Dec-Wed-09-Dec
Is there any grade for that smooth rod.
threated rod means is that ss too??
eskeyaar
Re: Newbie...
Postby REPRAP SQUAD » 2013-Dec-Wed-11-Dec
Depending on where you get the smooth rods. Some are cold rolled, oil rolled and even water rolled. Some are chromed. There is a discussion on RepRap forums about the different types and densities. Chromed rod is good for specific linear bearings and not for others. So it's all dependant on what your needs are and where you go to fulfill those needs.
Re: Newbie...
Thankyou guys,
Now what kind of smooth rod coming along with builders kit.? it just says 10' smooth rod. Is it Cold rolled? chromed ? I need much detail about it.
And what is the PLA filament diameter used in builders kit? is it same as simple printrbot printer pla filament dia?? cuz i need to get pla filament from different state in india.
for acme rod, is it ordinary threaded rod? any specification.?
Sorry for so many questions... :-)
Santosh
eskeyaar
Re: Newbie...
Postby REPRAP SQUAD » 2013-Dec-Sun-12-Dec
Re: Newbie...
Postby eskeyaar » 2014-Jan-Thu-02-Jan
Thankyou. Much Usefull....
eskeyaar
Re: Newbie...
Postby eskeyaar » 2014-Jan-Mon-07-Jan
Guys Is The 3d Model of Printrbot simple open in autodesk inventor 2012 or Pro-e Wildfire 5.0?
eskeyaar
Re: Newbie...
Postby eskeyaar » 2014-Jan-Sat-12-Jan
Hi guys, successfully today i laser cutted the files. But I face some problems in holes,
The instructions says use M3 screws but while the file in laser cut has 2.35mm.
eskeyaar
Re: Newbie...
Postby eskeyaar » 2014-Jan-Sat-13-Jan
Images of acyrlic.....
Santosh
eskeyaar
Re: Newbie...
Postby eskeyaar » 2014-Feb-Fri-02-Feb
Progress... Will Finish assembly soon...
i have question, regarding the attachment of 625z Bearing (miniature Deep Ball Groove), Is that we have to attach them tightly or should keep somewhat loose...???
Thanks
Santosh
eskeyaar
Re: Newbie...
Postby eskeyaar » 2014-Feb-Sat-15-Feb
Made them... perfectly running....
eskeyaar
Return to Buying
